fearofweapons Posted July 25, 2023 Share Posted July 25, 2023 Hello!  I've just changed the weeping fuel tank on the 1974 SWB SIII. When swapping the fuel pick up and return pipes over to the new tank I noticed that the tubes that dangle in the tank were the same length. (Long in case anyone was wondering 😉) Is this a problem? The car has worked OK(ish) so far. But LR would not have made the return in tank pipe short if there was no reason. Cheers Rich Quote Link to comment Share on other sites More sharing options...
markyboy Posted August 3, 2023 Share Posted August 3, 2023 On 7/25/2023 at 10:27 PM, fearofweapons said: Hello!  I've just changed the weeping fuel tank on the 1974 SWB SIII. When swapping the fuel pick up and return pipes over to the new tank I noticed that the tubes that dangle in the tank were the same length. (Long in case anyone was wondering 😉) Is this a problem? The car has worked OK(ish) so far. But LR would not have made the return in tank pipe short if there was no reason. Cheers Rich Shouldn't be a problem, it just means the fuel is returning to the bottom of the tank.  Regards, Mark Quote Link to comment Share on other sites More sharing options...
