3 MB petrol crank measurements
Little mule
Hi all I got a call from my machine shop today and they had a question for me .
im a defender RRC and disco guy so bear with me lol
the machine shop needs the min and max diameter of the surface for the rear crank seal  on a 3MB crank shaft .
they are trying to save a crank and need to know what they need to turn It down to .
any help would be greatly appreciated
tony
My WSM only has main bearing diameter listed-
2.500" std
with undersize in 0.010" increments to
2.460" max.
If I need info that I can't find , a quick call or email to Frida at Turner engineering usually provides the facts.
Steve
Hi Steve
thanks for the reply the machine shop already had those measurements.
the main reason I need the measurements for the rear oil seal surface is because the had to do some welding to save the crank for the gentleman .
personally. Would have swapped the engine out for a 5 MB but he is trying to do a full on restoration and keep as much of the original truck as possible .
thanks
Tony
