dono Posted October 19, 2023 Share Posted October 19, 2023 Hi folks , I'm new to the forum so go easy on me, I've recently bought a discovery 4 on a 11 plate ,auto, deisel 3.0 now i bought this with a fault that I thought I could get my head around and at the moment I'm scratching it, its with the epb , I know these vehicles have a common fault with the epb and by reading alot if different things it should have been a fix I could deal with but for whatever reason mine is not straight forward if I apply the brake it holds and works fine if I then put the vehicle in drive and pull away again it works fine ,you hear it wind back and all is well , but if after applying it I then push the swich down to release, it throws up a error message on the dash and won't clear until I turn off the ignition and restart, has anyone experienced this fault and can point me in the right direction as as far as I can tell all is well with the actuator as it does work both ways only not with the swich. Thanks in advance guys. Quote Link to comment Share on other sites More sharing options...
simonr Posted October 20, 2023 Share Posted October 20, 2023 I don't have a solution - but my guess would be the calibration. It senses the tension in the cables & load on the motor (most likely both by measuring the motor current). I would guess the required release current is too high - but when you put it in drive & start to roll, the movement helps push the shoes back in. When you replace the brake shoes, there's a calibration procedure - which seems, in part, to teach the EPP what's OK. I would get the park brake shoes replaced by someone with the right computer to do the calibration properly. (Welcome to LR4x4, by the way 🙂) Quote Link to comment Share on other sites More sharing options...
dono Posted October 20, 2023 Author Share Posted October 20, 2023 Thank you for the reply , that does sound plausable as it has had a recent pair of shoes fitted by the last owner , maybe not correctly , I am maybe going to have another look at it this coming weekend and see if I can adjust up the shoes correctly (weather pending) and more importantly see if there is any parts missing ie springs ect . We have a computer that does fault finds ect ect but I would imagine it may need a special software lr related to calibrate properly. Quote Link to comment Share on other sites More sharing options...
