Hawklord Posted February 1 Share Posted February 1 Can someone please confirm the correct part numbers for front and rear pads and pins/clips, whenever I think I have found the right PN another supplier shows them for a different vehicle or year. My discs are stock solid with no sensor needed on the pads. Any suggestions on which make to go for, vehicle is 99% road use. Quote Link to comment Share on other sites More sharing options...
western Posted February 1 Share Posted February 1 Mintex, Ferodo, Delphi are good makes. Front STC1275 or SFP000260 these have the pins & anti rattle coil springs, Rear STC1601 or SFP000260 these have the same pins, coil springs attachments to calipers Quote Link to comment Share on other sites More sharing options...
Hawklord Posted February 1 Author Share Posted February 1 (edited) Thanks but are you correct that SFP000260 is the correct part number for both front and rear ? Also should have said that it is a Defender 90. Edited February 1 by Hawklord Quote Link to comment Share on other sites More sharing options...
western Posted February 2 Share Posted February 2 Sorry rear is SFP000260 NOT as above, fat fingers & I didn't check read it after. Quote Link to comment Share on other sites More sharing options...
