PITBULL Posted February 11 Share Posted February 11 Any idea what this could be? Starts but ticks over real low about 4-500rpm for about a minute after being left overnight but even when restarting straight away ticks over for a few seconds low. Nothing happens when I press the accelerator when it ticking over low but as soon as it jumps to normal tick over drives fine 🤷♂️ I’ve tried: crank sensor off a working vehicle. Crank sensor shim New non return valve Quote Link to comment Share on other sites More sharing options...
bear Posted February 11 Share Posted February 11 Are you able to check the fuel pressure? Should be 4 bar at the FPR. Griff Quote Link to comment Share on other sites More sharing options...
