RGK Posted April 30 Share Posted April 30 Hi, I've installed my Disco 300tdi into a 1983 110. The injection pump fuel switch is electronic, could someone help me with decoding the 3 wires to the fuel switch? Which one do I use? what are the other 2 used for? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted April 30 Share Posted April 30 Thats the DDS security module, which links to the discovery alarm/security system. It is a box with a small electronic module inside, filled with silicon gel and secured over the stop solenoid with a clamp held by two security sheer bolts. The usual method is to remove the box & clamp with a sharp cold chisel and BFH, revealing the solenoid inside which you can then take an ignition feed to. Quote Link to comment Share on other sites More sharing options...
RGK Posted April 30 Author Share Posted April 30 thanks. so there's no way of using the existing wires? i need to smash the DDS off Quote Link to comment Share on other sites More sharing options...
