sheeppimp Posted February 6, 2007 Share Posted February 6, 2007 Hi, think this is the right place for this one, if not apologies. I need to sort the wheels for my 80in leafer as they're in a pretty poor state. Currently it has forward control rims fitted - better turning circle as more offset i believe. I could refurb them and fit new tyres but as they require tubes and mixing tubes and tubeless tyres just leads to punctures i'm not sure whether it might not be better to replace them? If i was to replace what with to give equal or greater offset without spending silly money? I seem to remember that some 8 spokes have a fair offset but i've seen others that are about standard - how can you tell which are which? Or would disco steels give enough offset to match the FC rims Any suggestions? cheers Toby Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 7, 2007 Share Posted February 7, 2007 If FC rims are rare then don't chuck them - but if you just need offset you can probably buy new steels for less than the cost of refurb. Anyone who sells wheels should be able to tell you the offset. Quote Link to comment Share on other sites More sharing options...
Corrode Finger Posted February 7, 2007 Share Posted February 7, 2007 I have been advised that when you buy new weller type wheels, you can specify the offset you want, fairly easy when you look at the wheel /tyre combo's that abound. Stating the obvious, but the best thing would be to measure the FC rims and request the same on ordering. I guess the only drawback with 'home refurbing' rims is getting a good finish such that you get a good finish for the tyres/tubes to seal/ sit on. Spose the other thing to consider is ensuring the rims clear the drums etc, so might have to buy new on the 'aftermarket rims'. Quote Link to comment Share on other sites More sharing options...
