soutie Posted May 27 Share Posted May 27 I have a 1989 110. I have bought a Sealey 2.5L Brake & Clutch Bleeding System, Model No. VS820. The cap size is 45MM which fits the brake Master cylinder reservoir, but not the clutch master cylinder. In my bin corner I have two old master cylinder which are scrap which the 45mm pressure bleeder cap fits, but not the one on my vehicle. Which of the following master cylinder will have a 45Mm cap that will fit the pressure bleeder? Or what pressure bleeder cap fits the part no. 550732? Quote Link to comment Share on other sites More sharing options...
steve b Posted May 28 Share Posted May 28 550732 is just the early numbering version of STC500100(G) - the MC is the same part for S3 all the way to 2006 . The bleeder cap fit is not as good as the brake res. fit, but mine will screw on and seal with a bit of effort. I use TRW OEM parts. Steve Quote Link to comment Share on other sites More sharing options...
soutie Posted May 29 Author Share Posted May 29 Steve Thanks for reply. I will try the TRW part. Peter Quote Link to comment Share on other sites More sharing options...
