Anglo-Frenchman Posted February 8, 2007 Share Posted February 8, 2007 Does anyone know the easiest way to access the heater controls on a 1993 Defender with aircon? I fitted a new set of speakers into the front speaker openings last month and because they are deeper than the original efforts, I made spacer boxes so that they would not foul at the back. None the less, the magnet on the RH one got stuck to the metal air flap thingy which directs the air either to the screen of the cab and when I used the shift lever, I think that the cable got pulled out because not the flap will not operate at all. Is it a case of removing the entire lower dash? Ta, Ged PS - The new speakers which cost 16,00EUR are SO much better than the original OEM ones that you have to wonder what little extra it would cost LR to fit decent ones in the first place! Quote Link to comment Share on other sites More sharing options...
LR90 Posted February 8, 2007 Share Posted February 8, 2007 you have to wonder what little extra it would cost LR to fit decent ones in the first place! other than it disables the heater Quote Link to comment Share on other sites More sharing options...
