calvin Posted March 21, 2007 Share Posted March 21, 2007 has anyone swapped the steering for a series to a more modern system (with power steering ) with a collapsing steering column and cutting out the relay? i have seen some info about this using non landrover steering boxes mounted to the outside of the chassis, but i am not clear if you can still use the upper part of the steering column or do you have to replace the whole lot with one from another vehicle (or will something from a defender go in) as i would like to keep the original series 3 wheel. some insight or advice would be useful. cheers Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 21, 2007 Share Posted March 21, 2007 Defender column bolts straight in but I don't think you can keep the Series wheel as it's got the wrong splines. I have a Disco-II PAS box on the 109: With defender column and RR wheel (to be replaced with something nicer as funds allow). Quote Link to comment Share on other sites More sharing options...
Gareth Dickens Posted March 23, 2007 Share Posted March 23, 2007 Defender column bolts straight in but I don't think you can keep the Series wheel as it's got the wrong splines. I have a Disco-II PAS box on the 109: With defender column and RR wheel (to be replaced with something nicer as funds allow). Later 110 defender column works well with same steering wheel, but who wants to keep the old bus steering wheel anyway? I used defender column, defender steering box, defender droparm, and Rangie rod end. Use the existing steering rod, but turn it around cause the rangie rod end is L/H thread. You will have to cut off the steering damper fitting on the steering rod and weld on a new one. ( If you want to keep the damper) Will have to lift the box to clear the leaf springs. I put 2 holes in approx. the mid of my chassis and built a little box structure above it for the other 2 bolts. For tubing the chassis use inners of shackle bushings. They work realy well. Sorry don't have photo's. Will take some this weekend. Quote Link to comment Share on other sites More sharing options...
calvin Posted March 24, 2007 Author Share Posted March 24, 2007 cheers for this, i will keep an eye out for the photos Quote Link to comment Share on other sites More sharing options...
Gareth Dickens Posted March 25, 2007 Share Posted March 25, 2007 My welding sucks but you should get the idea. Sticking to defender spares is easiest even if it might cost a little more than another option. My series3 steering wheel fits onto this defender column. (later defender according to the guy who gave me the column.) The second pic shows the rangietie rod end. The defender tie rod end has an attach point for the steering damper that I wouldn't use. Quote Link to comment Share on other sites More sharing options...
CR88 Posted April 23, 2007 Share Posted April 23, 2007 I found one disadvantage in this solution: - move the cross-member to me is, yes it's a disadvantage, I would prefer another that I can fit in the exterior of chassis, just because I have a new galv chassis. Other question but related. I don't want to change te engine for the moment. I have the 2.25 diesel engine, and naturally is limit to fit one oil pump for PAS. What I should do here? Quote Link to comment Share on other sites More sharing options...
