Disco 2 air compresson & tape measure
jules
Last week my air compressor for the rear springs was very noisy now there is no noise but also when I park up there is not the sound of it self leveling.
I think the whole air system is frozen up
can anyone that has a ES disco with 16" rims measure from the top of rim to the underside of arch as I think mine is very slowly dropping over the last 3-4 days.
I have just measured it a 222mm Or 8 3/4"
Thanks
Jules
If it isn't leaking it should in theory last forever I guess?
Maybe there is an air leak between the pump and the valve block and so the pump ran continuously trying to bring up the supply pressure till it went phut and now there is no pump...
Have you checked all the fuses etc?
