Martin90 Posted March 29, 2007 Share Posted March 29, 2007 Can anybody help me, I want to know if the input shaft splines are the same on V8 and TDi versions of the LT-77. The reason for this is I need to use a 9.5" clutch plate to fit in my Mazda engines clutch cover and I have a V8 gearbox that normally has a 10.5" clutch. Any help would be greatly appreciated! Cheers, Martin Quote Link to comment Share on other sites More sharing options...
nickm Posted March 30, 2007 Share Posted March 30, 2007 Can anybody help me, I want to know if the input shaft splines are the same on V8 and TDi versions of the LT-77. The reason for this is I need to use a 9.5" clutch plate to fit in my Mazda engines clutch cover and I have a V8 gearbox that normally has a 10.5" clutch. Any help would be greatly appreciated! Cheers, Martin think the splines are the same but from wot i remember the shaft on a diesel is shorter than the v8 sure someone will know for sure Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted March 31, 2007 Share Posted March 31, 2007 That is certainly true with an R380, so I would reckon the very similar LT77 will be the same. Quote Link to comment Share on other sites More sharing options...
