JST Posted April 14, 2007 Share Posted April 14, 2007 Les, did you change the position of the crawler actuator or did it come with the selector exiting the rear of the body? just noticed its the other way around on others i have seen. do you knwo if its interchangeable? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 14, 2007 Share Posted April 14, 2007 James, If came that way, but from what I can remember when I had it all apart there is no reason why it can't be changed round , Although I'm sure Dave will be along in a mo to say the opposite and then I'll have to change mine Yep I've found yer pump the other day when digging out the Hydro PTO pump, and yes I can Marshall on the 5th Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 14, 2007 Share Posted April 14, 2007 James,If came that way, but from what I can remember when I had it all apart there is no reason why it can't be changed round , Although I'm sure Dave will be along in a mo to say the opposite and then I'll have to change mine Yep I've found yer pump the other day when digging out the Hydro PTO pump, and yes I can Marshall on the 5th Les, it was that way round when FB had it on his buggy. I've got basically the same setup but the other way round and its a bit tight against the side of the autobox. Quote Link to comment Share on other sites More sharing options...
