Box section in front of rear wheel arch Defender
Paul64
Hi,
Is the box section at the front of the rear wheel arch on a defender simply rivited in? It looks like it from the outside as there are a row of external rivets. Or is that just the outer skin? The reason I ask is that I can see some rust on the inside close to and including the rear seat mounting bracket. Looks like it will need changing soon, but not sure if it is a welding job?
The lower door seal looks well worn and I can imagine water and muck has crept in and up that panel.
Cheers,
Paul.
