Pat Posted April 19, 2007 Share Posted April 19, 2007 Will a defender bumper fit a series three? Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 19, 2007 Share Posted April 19, 2007 yes it will but it will fit further back towards the wings than standard Quote Link to comment Share on other sites More sharing options...
Pat Posted April 19, 2007 Author Share Posted April 19, 2007 yes it will but it will fit further back towards the wings than standard Cheers for that, i am in need for a winch bumper and was considering using one from a defender as there seems to be more choice. Its for a warn 8274. Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 19, 2007 Share Posted April 19, 2007 you need to take into consideration the side lugs on a defender winch bumper which bolt through the dumb irons then, these may need modifying to fit the series ones, easy enough if you're good with a welder Quote Link to comment Share on other sites More sharing options...
92.9 Posted April 21, 2007 Share Posted April 21, 2007 I've got a Defender winch bumper for the Series project I am doing at the moment. I have offered it up and the bolt holes are in the right place. The only thing that needs modifying is where the mounting 'tags' slide above and below the front of the chassis members to mount it: the top tags are fine, but where the bottom tags slide into the boxed recess of the front spring hangers, the bottom tags are a bit wide towards their inner edges and need two or three millimetres grinding off. This doesn't go anywhere near the bolt holes so won't affect its strength. Mike Quote Link to comment Share on other sites More sharing options...
