dave101 Posted April 24, 2007 Share Posted April 24, 2007 Are there different diameter lower spring mounts for coil sprung vehicles? I bought some springs (at sodbury) marked as 90 rear heavy duty, but they are a larger overall diameter than the original ones and don't locate correctly on the lower mounts. David Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2007 Share Posted April 24, 2007 Probably 110 rears, they use a larger diameter spring. 90's use NRC9700 oR ANR3578 depending on chassis number 110's use NRC4317 on all models of 110 including the 127/130. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 25, 2007 Share Posted April 25, 2007 Are there different diameter lower spring mounts for coil sprung vehicles? I bought some springs (at sodbury) marked as 90 rear heavy duty, but they are a larger overall diameter than the original ones and don't locate correctly on the lower mounts.David Sounds like you've bought some 110 springs David. unfortunately they won't fit into a 90. even if you fit the lower mounting brackets that Ralph quoted above, the upper bracket that's welded onto your chassis will be the wrong size. Quote Link to comment Share on other sites More sharing options...
