MRWOO Posted May 28, 2007 Share Posted May 28, 2007 Does anybody know if the main shaft into the transfer is cross drilled for lubrication? I do hope Land Rover haven't engineered this problem back in? Quote Link to comment Share on other sites More sharing options...
western Posted May 28, 2007 Share Posted May 28, 2007 Would have thought so, with the latest incarnation of the LT230 Transferbox fitted. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 29, 2007 Share Posted May 29, 2007 Is there any particular reason you ask?? Quote Link to comment Share on other sites More sharing options...
MRWOO Posted May 29, 2007 Author Share Posted May 29, 2007 Is there any particular reason you ask?? No not really, other than I know how many time this has failed in the past. I didn't think having the new incarnation of the transfer box makes any difference, I thought the cross drilled shaft was the main shaft from the gearbox? Seeing as this is a new gearbox for Landrover (i.e Ford) the shaft may not be cross drilled... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 29, 2007 Share Posted May 29, 2007 No not really, other than I know how many time this has failed in the past. I didn't think having the new incarnation of the transfer box makes any difference, I thought the cross drilled shaft was the main shaft from the gearbox? Seeing as this is a new gearbox for Landrover (i.e Ford) the shaft may not be cross drilled... It's actually the gear that's in the transfer that is cross drilled. the "main shaft" from the back of the gearbox is solid. Quote Link to comment Share on other sites More sharing options...
MRWOO Posted May 29, 2007 Author Share Posted May 29, 2007 It's actually the gear that's in the transfer that is cross drilled. the "main shaft" from the back of the gearbox is solid. Thanks for that Jim. Quote Link to comment Share on other sites More sharing options...
