jeremy Posted May 29, 2007 Share Posted May 29, 2007 Over the weekend I've had a bit of a disaster in my 90!........again! The shock absorber mount on the off side of the rear axle has parted company with the rest of the axle. Close examination shows the axle is far rustier than I originally realised before I fitted it only a couple of months ago. I don't think repairing it is an option. I can get my hands on another Range Rover rear axle that is in much better condition but the shock mounts are in apposing directions (ie off later model RR). Are the shock mounts available as a part that can be welded on? If so who sells them? I've checked the technical archive and couldn't see anything there relating to this, but I know people who have done this in the past. Have checked with local suppliers and national suppliers websites and couldn't see anything listed. Quote Link to comment Share on other sites More sharing options...
nige90 Posted May 29, 2007 Share Posted May 29, 2007 I fabbed a bracket out of 4mm plate and welded it on. Still fine two years and many miles later. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 29, 2007 Share Posted May 29, 2007 I can get my hands on another Range Rover rear axle that is in much better condition but the shock mounts are in apposing directions (ie off later model RR). opposing mounted shocks mean that it's an early axle, very early. I think paddocks (in their 27 page advert in the comics) sell the weld on shock and trailing arm mounts. Quote Link to comment Share on other sites More sharing options...
michael calvert Posted May 29, 2007 Share Posted May 29, 2007 opposing mounted shocks mean that it's an early axle, very early.I think paddocks (in their 27 page advert in the comics) sell the weld on shock and trailing arm mounts. can you not just move the shocker mounting on the defender chasis as they are drilled for both positions? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 29, 2007 Share Posted May 29, 2007 That'd require pretty extensive fabrication on the chassis, there's no rear shock pointing holes in the chassis. Quote Link to comment Share on other sites More sharing options...
