Les Henson Posted June 4, 2007 Share Posted June 4, 2007 P38 Rangy - Beemer diesel, runs rough as Nige's skin tone Testbook code is saying - Code 144 injection control what how if why etc Expensive prezzie to the winner. Confused of Swindon. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 4, 2007 Share Posted June 4, 2007 Les, It's the injection control that is broken Seriously though if it is a Testbook/T4/IDS does it give a list of possible causes? Or is it just a generic "code reader" you are using? Usually the proper article gives you a bit more information on the possible problem. I'm not familiar with the BMW motor but some engines around that time use an injector pump which seemingly does the main injector pumpy things by itself but the injection timing is modified by the ECU - the L series in the Freeloader works like this I think. So it will run without the electronics working properly but not very well - could be something like that. I'm afraid I know nowt about the engines as there is only one P38 RR here and I looked under the bonnet for the first time last week Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 4, 2007 Share Posted June 4, 2007 a bit of help on rangie.com, it mentions that the same engine is used in the omega, and apparently there's quite a bit of info on the interweb on those. Quote Link to comment Share on other sites More sharing options...
