poacher Posted June 4, 2007 Share Posted June 4, 2007 Hi folks, seeing as the above are few & far between (or at reasonable prices), has anyone got a template for the repair sections around the top retainers? I know I'm being lazy but I just don't have the time to measure at the moment I had originally ordered a new bulkhead for mine but 2 weeks later & it still hadn't arrived so cancelled the order. I need to repair drivers side post between the 2 hinges too. Gives me more practice at my welding I suppose!!! Cheers Dave Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2007 Share Posted June 4, 2007 Have a look here click 'Parts' then Defender door repair section Quote Link to comment Share on other sites More sharing options...
poacher Posted June 4, 2007 Author Share Posted June 4, 2007 Is that the channel where the anti swing bracket sits? Mine is more the edge of the door frame if that makes sense, sorry for not being clearer. Useful site though. Dave Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2007 Share Posted June 4, 2007 (edited) No, it's just a generic repair section for the door frame. have look on ebay [if you haven't already] for another door that may replace yours or give up the section you need. these photo's might help Edited June 4, 2007 by western photo's added Quote Link to comment Share on other sites More sharing options...
poacher Posted June 4, 2007 Author Share Posted June 4, 2007 Hi, tried ebay, like rocking horse muck!!! Definately going to get some seat box ends though. Spot on site that, wish I had it earlier when I renewed my disco inner wing @ £70 quid!!!! Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2007 Share Posted June 4, 2007 (edited) Just found the check strap bracket on the door in EPC, it's shown as a replacable part ALR1801 for LH & ALR2684 for RH, I'll add the appropriate page in a moment. I found that site a few months ago, while looking around on ebay here's the front door parts page as promised --- it's item 18, I've written in the part numbers as they are different for each side. FRONT_DOOR_PARTS.pdf Edited June 4, 2007 by western parts page added. Quote Link to comment Share on other sites More sharing options...
poacher Posted June 5, 2007 Author Share Posted June 5, 2007 Many thanks, mine has gone a little above the check straps, almost at the top where the window frame meets. I think I'll plate it (should get away with it), will still need a check strap though, old type by the looks of it. Cheers Dave Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2007 Share Posted June 5, 2007 good to know that helped, the older rod type check bar is LH-----MUC1889 RH-----MUC1888 not sure if these are still available though. Quote Link to comment Share on other sites More sharing options...
poacher Posted June 5, 2007 Author Share Posted June 5, 2007 I thought that not long after I posted, I suppose I could adapt a newer one, if the holes in the bulkhead line up!!! Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2007 Share Posted June 5, 2007 you could use the later plate type bar as per my photo's above, IIRC the pivot pin & roller diameters are the same, worth a try. Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2007 Share Posted June 11, 2007 further to obtaining new check rods, I've seen a complete kit on ebay this evening, still with days to run, here it is Quote Link to comment Share on other sites More sharing options...
poacher Posted June 11, 2007 Author Share Posted June 11, 2007 Much appreciated Quote Link to comment Share on other sites More sharing options...
