Se7enUp Posted June 11, 2007 Share Posted June 11, 2007 I have a friend who can make me a couple of spreader plates for my newly aquired Nato Hitch. Does anyone here have a diagram, drawing or a plan showing the required dimensions of the plates and location/diameter of the holes. (I'm putting a plate on both the front and rear of the crossmember) I'm knowhere near my Landie at the moment co can't get to measure it up Any help appreciated Quote Link to comment Share on other sites More sharing options...
Se7enUp Posted June 11, 2007 Author Share Posted June 11, 2007 By spreaders I mean the plate bits in these photos (shamlesly copied from HFH's recovery article) Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 11, 2007 Share Posted June 11, 2007 I might have one somewhere - will have a look later. The vehicle that towing hitch was bolted to is no longer mine so I don't have those two Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 11, 2007 Share Posted June 11, 2007 The plate is about 5 or 6mm thick IIRC. not sure about the external dimension, but it's only got to fit in the gap behind the crossmember. the holes for the hitch bolts are: 13/4" x 33/8" (thats 44.5mm x 85.72mm) diameter is 9/16" (14.27mm) these are taken from the dixon bate spec sheet for the hitch. Quote Link to comment Share on other sites More sharing options...
Se7enUp Posted June 11, 2007 Author Share Posted June 11, 2007 Thanks guys I didn't think of looking for a spec sheet - Doh! Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted June 11, 2007 Share Posted June 11, 2007 Hi, made this for mine, IIRC....... Outer plate 200 x 140 x 10mm, drilled 86x44.5, holes positioned central & 40mm down from top edge. Inner plate 200 x 130 x 10mm, centralized (5mm top/btm). Drilled 13mm dia & secured with M12 bolts. Rod Quote Link to comment Share on other sites More sharing options...
Se7enUp Posted June 12, 2007 Author Share Posted June 12, 2007 Rod, Thats brilliant - just what I needed. Cheers Steve Quote Link to comment Share on other sites More sharing options...
