Disco_Dunk Posted June 22, 2007 Share Posted June 22, 2007 I now have BOTH my Disco's with passenger doors that don't unlock with the zapper so it looks like I'm gonna have to bite the bullet and sort them out. I've replaced the lock-spring on a rear door, but are the side doors any easier or harder? Dunk Quote Link to comment Share on other sites More sharing options...
russ3120 Posted June 22, 2007 Share Posted June 22, 2007 Dunk I will let you know doing mine this weekend russ Quote Link to comment Share on other sites More sharing options...
wizard Posted June 22, 2007 Share Posted June 22, 2007 All the doors are identical in fiddlyness !!!!!!!!!!! If the spring hasnt broken it could be the actuating solenoid thats playing up. wizard Quote Link to comment Share on other sites More sharing options...
Disco_Dunk Posted June 22, 2007 Author Share Posted June 22, 2007 All the doors are identical in fiddlyness !!!!!!!!!!!If the spring hasnt broken it could be the actuating solenoid thats playing up. wizard heh - not on my commercial it's not.... good old fashioned wind-up windows. No mod cons!!! Russ...... let me know how you get on! Cheers Dunk Quote Link to comment Share on other sites More sharing options...
russ3120 Posted June 27, 2007 Share Posted June 27, 2007 heh - not on my commercial it's not.... good old fashioned wind-up windows. No mod cons!!! Russ...... let me know how you get on! Cheers Dunk didnt manage to get the door lock springs done, no garage and lots of rain had something to do with it. Russ Quote Link to comment Share on other sites More sharing options...
Disco_Dunk Posted June 27, 2007 Author Share Posted June 27, 2007 didnt manage to get the door lock springs done, no garage and lots of rain had something to do with it.Russ Hi Russ - no worries...... I might have a crack at one of mine this weekend (in the garage! - damn weather). Depends how I get on with taking the gearbox out first...... errr that's not a pre-requisite for the door-springs, just another job I've got on the go (synchro? what synchro???)!!! Dunk Quote Link to comment Share on other sites More sharing options...
Mark Posted June 27, 2007 Share Posted June 27, 2007 As has been mentioned it's a fiddly job, and seemed to involve taking the entireity of the front door apart - including removing the window frame! It's not had, just fiddly! Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted July 20, 2008 Share Posted July 20, 2008 Hi I've done a couple of my door springs. Got them from "Disco-compatible-parts.com". Though the first one I did was on the back door, where I pinched the spring from the Child lock Lever, and used that . Remember to wire the child lock off if the spring is removed. Also spray with "Chain Lube" after fitting to avoid them rusting away in the future. Quote Link to comment Share on other sites More sharing options...
