Coastcard Posted July 3, 2007 Share Posted July 3, 2007 A quicky that I couldn't find in the excellent swivel or bearing overhall threads. How do you remove the brass bush in the front stub axle so that the oil seal can be replaced? Is it a hub puller job? Thanks. Quote Link to comment Share on other sites More sharing options...
MickStobbs Posted July 4, 2007 Share Posted July 4, 2007 Hello mate,put it in a vice with the bush facing upwards(don't grip it where the bearing fits)use a centre punch or a small tap to mark a start spot for drilling midway between the inner and outer diameter.Then drill down through the bush with a drill as near to the size of the flat surface as tou can get.Only go down as far as the bottom of the bush till it hits the steel below.What you have now is a weak point in the bush so ,now, use a hammer and punch to hit the bush towards the centre,(hit it just to the side of the drilled hole).The bush should collapse inwards and lever out easily Hope this has been of some help,Mick. Quote Link to comment Share on other sites More sharing options...
Paul Posted July 4, 2007 Share Posted July 4, 2007 Alternativley, since you'll be replacing the seal (or leaving it out altogether), you can use the seal to push the bronze bush out without damaging the bush. Put the stub axle on a vise bush side down, with the vise open wide enough allow the bush to be knocked through. Get a thin rod or an old screwdriver with the tip bent at a 45° angle that can reach though the stub axle and get behind the seal. Knock out the seal and it'll knock out the bush on the way through. Paul Quote Link to comment Share on other sites More sharing options...
Coastcard Posted July 5, 2007 Author Share Posted July 5, 2007 Thanks guys. Will try option 2 first me thinks as potentially less damaging especially as yesterday there was a smell of burning and then my pillar drill stopped working Quote Link to comment Share on other sites More sharing options...
