JSG Posted July 5, 2007 Share Posted July 5, 2007 When I bought the 110 I decided against paying the price the dealer wanted to bolt a tow bar to the back and decided to wait and look at the options. Now I seem to recall reading something about approvals etc for towing equipment fitted after a certain date - is this as simple as buying a tow bar with the correct stickers and fitting yourself (not hard to a 110) or is it supposed to be fitted by an approved installer only these days? I'm also assuming that these days even a Defender has the connector in the wiring loom for the towing electrics to be simply plugged in. Can anyone clarify the above? Cheers, John. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted July 5, 2007 Share Posted July 5, 2007 When I bought the 110 I decided against paying the price the dealer wanted to bolt a tow bar to the back and decided to wait and look at the options.Now I seem to recall reading something about approvals etc for towing equipment fitted after a certain date - is this as simple as buying a tow bar with the correct stickers and fitting yourself (not hard to a 110) or is it supposed to be fitted by an approved installer only these days? I'm also assuming that these days even a Defender has the connector in the wiring loom for the towing electrics to be simply plugged in. Can anyone clarify the above? Cheers, John. i beleive the cut off date was 1998 Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted July 5, 2007 Share Posted July 5, 2007 i beleive the cut off date was 1998 found it http://www.ntta.co.uk/law/towbars/type_approval.htm Quote Link to comment Share on other sites More sharing options...
