marsie Posted July 11, 2007 Share Posted July 11, 2007 How much backlash is acceptable on a defender transfer box(230).Was under mine today and found i had about 20mm of free play at the handbrake(outer edge) end before taking up the slack.I cant say i have ever noticed this before but then again i dont think i have ever looked .I have checked the oil for nasties but its clean,am i worrying too much??? Paul Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 11, 2007 Share Posted July 11, 2007 There's always a significant amount of play between turning one prop and the other moving. Les. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 11, 2007 Share Posted July 11, 2007 How much backlash is acceptable on a defender transfer box(230).Was under mine today and found i had about 20mm of free play at the handbrake(outer edge) end before taking up the slack. i wish i had only 20mm of play.... Quote Link to comment Share on other sites More sharing options...
Coastcard Posted July 11, 2007 Share Posted July 11, 2007 As above, doesn't sound too drastic. You don't say how old your vehicle is, but if you are concerned about these things (and not already fitted), you can go down the preventative route of drilled input gear (xfer box) or an oil feed. Both are relatively inexpensive and simple solutions to the worn spline issue. Quote Link to comment Share on other sites More sharing options...
marsie Posted July 11, 2007 Author Share Posted July 11, 2007 I will stop panicking then ,just seems funny i have never noticed it before.Got the TFC next month and didnt want to travel 350miles and then the tranny box explode on the first section Thanks for the info guys Paul Quote Link to comment Share on other sites More sharing options...
marsie Posted July 11, 2007 Author Share Posted July 11, 2007 As above, doesn't sound too drastic. You don't say how old your vehicle is, but if you are concerned about these things (and not already fitted), you can go down the preventative route of drilled input gear (xfer box) or an oil feed. Both are relatively inexpensive and simple solutions to the worn spline issue. Its a 1997 300tdi with 90000miles.The last 10000 have been rough use(winch challenges etc).Just wanted another opinion to put my mind at rest especially now the transfer box is the weakest link since fitting beefed up halfshafts/cvs etc. Paul Quote Link to comment Share on other sites More sharing options...
