nobber Posted July 21, 2007 Share Posted July 21, 2007 does the little pin on the diaphragm go towords the pump or towords the engine block? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 21, 2007 Share Posted July 21, 2007 does the little pin on the diaphragm go towords the pump or towords the engine block? towards the block i think, then you turn it clockwise to increase the on boost fuelling. Quote Link to comment Share on other sites More sharing options...
nobber Posted July 21, 2007 Author Share Posted July 21, 2007 towards the block i think, then you turn it clockwise to increase the on boost fuelling. turn it clockwise , increase boost , ? way over my head jim , i just made it the same size as the pin on the old one. would this make it go faster then? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 22, 2007 Share Posted July 22, 2007 I think we might need a clearer picture of what you are talking about. Jim is referring to the shaft attached to the diaphragm on a Bosch VE pump. It has an eccentric cone on the end that control the fueling rate as boost increases. Depending on which angle this is set at, the fueling rate varies. Quote Link to comment Share on other sites More sharing options...
nobber Posted July 22, 2007 Author Share Posted July 22, 2007 ah , im on about the little delphi diaphragm that i think sends fuel to the turbo , its in a housing on the engine side of the dsp ? thingy. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted July 22, 2007 Share Posted July 22, 2007 Fuel doesn't get sent to the turbo, turbo pressure 'gets sent' to the fuel pump. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 23, 2007 Share Posted July 23, 2007 Yah, sorry, maybe a picture. It is still not making sense to me what you are talking about. The diaphram on the injection pump moves with turbo pressure in order for the fueling to be adjusted as the pressure changes. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 23, 2007 Share Posted July 23, 2007 Do you mean this bit: you can see that "normally" the dot is at the top, closest to the engine block. it's turned around to between 3 o'clock and 6 o'clock for extra oomph. Quote Link to comment Share on other sites More sharing options...
