fester Posted August 15, 2007 Share Posted August 15, 2007 i have a set of 33,12.50,R15s on my series and wondered if they would killthe arches on my standard 90???? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 15, 2007 Share Posted August 15, 2007 They will fit but there will be some rubbing without a lift but usually non damaging. I've had BFGs in this size on all 3 of my vehicles with no bother. The most important thing is wheel size and offset you need 8x15 white 8 spokes on a fairly standard offset - so the tyres are about level with, or half an inch outside of, the plastic eyebrows, if they stick out more than that then you will have problems. Quote Link to comment Share on other sites More sharing options...
j90 mud Posted August 17, 2007 Share Posted August 17, 2007 they will fit without a lift but will catch in the usual places. even with a 8 inch rim they will stick out past the std archs enough to cover the side of the car in mud etc and the yes of the law.i run a set with 10 rims with good offset and they are still pround of archs by 1 inch approx dependant on what suspension you use they will also catch the std archs when you cross axle vehicle on rear ,so you will need to trim archs as per most challenge cars Quote Link to comment Share on other sites More sharing options...
