2nd gear
manic
hi all when changing from first to second i get a crunch ! could this be cured with an oil change or adjustment of the clutch, orf more serious
They all do it to some extent, taking your time on the shift helps. Check what oil you have in gearbox (do you have LT77 or R380?) Should be ATF at least or preferably MTF94, Difflocks Evo1 is good. I found previous owner of mine had topped up with EP90!! Still notchy though especially cold.
