Peterla Posted September 9, 2007 Share Posted September 9, 2007 Can anyone tell me how to replace my ignition key switch as mine is worn out. It looks like the switch is rivited and clamped to the steering shaft. Can a second hand switch be used to replace my old one as not sure how to replace the rivets. Any help would be greatly appreciated Thanks Peter Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 9, 2007 Share Posted September 9, 2007 The 'rivets' are security bolts. When they are tightened the head snaps off so that they theoretically can't be undone. A centre punch, hammer, and a bit of patience will undo them however and the switch can easily be replaced. Either use M8 coarse allen bolts to replace the security items, or buy new bolts from the usual suppliers. Les. Quote Link to comment Share on other sites More sharing options...
Peterla Posted September 11, 2007 Author Share Posted September 11, 2007 The 'rivets' are security bolts. When they are tightened the head snaps off so that they theoretically can't be undone. A centre punch, hammer, and a bit of patience will undo them however and the switch can easily be replaced. Either use M8 coarse allen bolts to replace the security items, or buy new bolts from the usual suppliers.Les. Thanks Les The punch worked fine after I dropped the steering coloum so I could get to them. Pete Quote Link to comment Share on other sites More sharing options...
nickm Posted September 12, 2007 Share Posted September 12, 2007 Thanks LesThe punch worked fine after I dropped the steering coloum so I could get to them. Pete other way would be is to use a thin cutting disc and make a slot in the security bolt that way u can just use a screw driver to undo it think you only need to undo the one nearest the ignition barrel which would still leave 1 security bolt untouched Quote Link to comment Share on other sites More sharing options...
