Spare wheel mount dimensions
Orange
I'm trying to come up with a solution to mounting my bigger-than-standard spare wheel in the back of my Range Rover..... Why the Defender forum, then, I hear you ask - bear with me!!
I've got an idea to mount a standard defender/series spare wheel mounting bracket (the rear door type) on the inner wing, but don't have one and haven't got a vehicle close by to be able to measure...
Can comeone give me the dimensions of the back plate and the length of the 3 studs that come off of it please? Also, how many mounting holes are there in the back plate?
Much obliged...
Adrian
10 1/2" across
7 1/2" up/down
3 off 8" studs also used as mounts through rear door.
11 M6 retaining bolts
           B        B
     B                  B
B                              B
B                              B
     B                  B
               B
Cheers for the dimensions chaps...
Mo - I will take you up on the offer, but am not sure when I'm next in your neck of the woods! Will drop you a message once SWMBO has spoken to her mum and arranged something - if you don't mind holding on to it for now...
Ta!
