ltwt1981 Posted September 19, 2007 Share Posted September 19, 2007 Noticed this morning on the Disco TD5 when stopped at office a noise like a bearing or similar. Best I can describe it is like the old lughtweight had an idler on the fan belt that always seemed to run on and make a noise. Ran on for probably 30 seconds or so. By the time I got the bonnet up it had stopped so restarted it stopped it and no noise. Coming from left front end, could it be the turbo although I thought they just went. Any idlers on the belts etc? Any help appreciated but it will only get worse and then I'll know what it is. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted September 19, 2007 Share Posted September 19, 2007 It's the centrifugal oil filter spinning down after the engine has stopped. Scares lots of new TD5 owners so you are not alone. Some Engines do it and some don't. Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted September 19, 2007 Author Share Posted September 19, 2007 Many thanks, worried me as its only just started to do it after a service. Quote Link to comment Share on other sites More sharing options...
lynall Posted September 23, 2007 Share Posted September 23, 2007 Many thanks, worried me as its only just started to do it after a service. Which would be the new spinner i have serviced mine several times and some makes of filter do it and others dont. Lynall Quote Link to comment Share on other sites More sharing options...
