pugwash Posted September 21, 2007 Share Posted September 21, 2007 I've been playing with memory map which i installed recently and i can't quite work out how to map waypoints. If i Quote Link to comment Share on other sites More sharing options...
Peatbog Posted September 21, 2007 Share Posted September 21, 2007 Click 'search', then 'find place'. it'll open a window where you can enter a placename, or in the lower half you can enter the coordinates. make sure you check the 'create a mark at location'. thats how i do it anyway, if there's another way i ain't found it yet. Quote Link to comment Share on other sites More sharing options...
widget Posted September 22, 2007 Share Posted September 22, 2007 I've been playing with memory map which i installed recently and i can't quite work out how to map waypoints. Select route or marks from the menu bar - and click on the screen. There is a comprehensive help section also. Quote Link to comment Share on other sites More sharing options...
