Shox Dr Posted October 11, 2007 Share Posted October 11, 2007 Hi I've fitted an electrical fan out of a Mondeo to my 300tdi Defender 90 Can anyone advise of the correct Temp sender value. Sender is fitted to the return from the rad Cheers Quote Link to comment Share on other sites More sharing options...
Gromit Posted October 11, 2007 Share Posted October 11, 2007 Is your sender adjustable? If so, just run the engine until the coolant is at running temp, turn the sender down till the fan starts, then turn it up a smidge til the fan stops. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted October 11, 2007 Share Posted October 11, 2007 http://www.x-eng.co.uk/X-ThermData.asp Quote Link to comment Share on other sites More sharing options...
Shox Dr Posted October 11, 2007 Author Share Posted October 11, 2007 Thanks for the replies. I havn't got the sender yet. What I need is the temp, the fan should turn on at. The link only gives the part numbers relating to temps. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted October 11, 2007 Share Posted October 11, 2007 the link says: " The one we supply (an Intermotor 50091) we feel is most generally suited to Land Rover temperatures". That is 88-83 degrees. It's just an opinion (theirs). Mine would be to choose one with: - ON temp: 0..2 degrees over the thermostat temp. - OFF temp: 3...5 degrees below thermostat temp. Quote Link to comment Share on other sites More sharing options...
Shox Dr Posted October 12, 2007 Author Share Posted October 12, 2007 the link says: " The one we supply (an Intermotor 50091) we feel is most generally suited to Land Rover temperatures". That is 88-83 degrees.It's just an opinion (theirs). Mine would be to choose one with: - ON temp: 0..2 degrees over the thermostat temp. - OFF temp: 3...5 degrees below thermostat temp. Thnaks for that, I'd just come off shift and wasn't exactly awake Quote Link to comment Share on other sites More sharing options...
