xyra Posted October 23, 2007 Share Posted October 23, 2007 Hi, I've got a 1986 landrover 90 with a leaking diesel injector pump. I've picked up a second hand reconditioned injector pump (from someone who had it reconned then sold his landy before he fitted it) I need to fit it, but not sure how to go about it/what tools I need. I've done most other tasks on the vehicle but not ventured near the cambelt/pump area. It did have it's cambelt replaced about 5000 miles ago so hopefully things shouldn't be to tight. I've got all the gaskets I think I need, but not got any pullers/pins and would like to do this on a reasonable budget I already have the front of the vehicle off as i resoldered the radiator ad don't want to put it back on just to pay a garage to take it off again! Any info (or if anyone knows of a jobbing mechanic in south hampshire who can come and do it) would be great... Graham Quote Link to comment Share on other sites More sharing options...
Ex Member Posted October 23, 2007 Share Posted October 23, 2007 Workshop manuals here: http://www.landrover.ee/est/varia/downloads/downloads.htm Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 23, 2007 Share Posted October 23, 2007 I have to do this same job this week, so if you're not in a rush I could do a thread on it and post it at the weekend? It'll include remove old one - including timing belt, and replace with a re-con item. Les. Quote Link to comment Share on other sites More sharing options...
xyra Posted October 23, 2007 Author Share Posted October 23, 2007 Sounds good. Does it need any special tools? The workshop manuals talk about pullers and pins for the crank shaft - can I improvise with something else and diy pullers? If so I will give it a go after you post the thread. Edit: what size socket do I need to obtain to undo the crank shaft bolt? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 23, 2007 Share Posted October 23, 2007 You can make a very simple puller out of a bar of metal and two hi-tensile (you might get away with normal bolts) The bolt head I will be undoing will be 41mm, but there are two sizes - 32mm I think, so you need to check yours. Les. Quote Link to comment Share on other sites More sharing options...
xyra Posted October 29, 2007 Author Share Posted October 29, 2007 Many thanks for all that & posting the walk through. I'm going to give it a go this week. I'll let you know how it goes. Thanks, Graham Quote Link to comment Share on other sites More sharing options...
