sotal Posted November 6, 2007 Share Posted November 6, 2007 Where is the OBDII located on a Discovery 1?? From what I have read all vehicles from 1996 are supposed to have them, my Disco is a 1995 registered vehicle but it apparently is a 96 Model, I know it might not have a OBDII port but if it did where would it be located? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted November 6, 2007 Share Posted November 6, 2007 Right about here: 1995 models didn't have this connector. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 6, 2007 Share Posted November 6, 2007 If it has EDC it must have the Testbook port I think... If the VIN number is MAxxxxxx then it is a 95, if it is TAxxxxxx then it is a 96 Quote Link to comment Share on other sites More sharing options...
sotal Posted November 6, 2007 Author Share Posted November 6, 2007 Hi Thanks for the replies, it's a TA 96, I'll have a look for that connector, is the OBD2 port the same as the testbook port? If it has got the OBD2 port do you know what info can be obtained from it? Quote Link to comment Share on other sites More sharing options...
sotal Posted November 6, 2007 Author Share Posted November 6, 2007 I was hoping that a scangauge II could plug into it - any ideas if it would work? Quote Link to comment Share on other sites More sharing options...
sotal Posted November 6, 2007 Author Share Posted November 6, 2007 Well it has the OBD2 port, a 16pin connector with eight wires attached, any idea if scangauge will work? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted November 6, 2007 Share Posted November 6, 2007 It doesn't. Why? Because: 1. There's no mention of LR's in their compatibility list: http://www.scangauge.com/support/CompatibleVehicles.shtml 2. The protocol used is LR proprietary and not fully OBD compliant (there are some codes you can read on petrol engines). Quote Link to comment Share on other sites More sharing options...
sotal Posted November 6, 2007 Author Share Posted November 6, 2007 Thanks for the info cipx2, is this port the testbook port? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted November 6, 2007 Share Posted November 6, 2007 Yep, that's the one. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 7, 2007 Share Posted November 7, 2007 Hmmm...i've got one of them...can you get any useful information out of it on a diesel? Diagnoses for strange vibrating noises perhaps? Quote Link to comment Share on other sites More sharing options...
