Something seized
sotal
I have a complete but buggered S3 gearbox and xfer case for u. Maybe u can build one box from the two. I stripped the first gear so maybe the shafts are bent. Otherwise I will dump it at Rob Leimer's.
Thanks Gareth,
Thats good of you thanks, I will take it.
Sent you a PM.
Bill tell us more about putting a S3 layshaft into a 2a box please.
This conversion addresses the problem of layshaft flex and fatigue breakage in the second gear area common on series1,2 and 3 gearboxes and involves grinding off 1st and reverse gear teeth from a scrap series 3 cluster gear and grinding or milling the four coarse splines that accept the series 2 press on 1st gear pinion. the splining obviosely needs to be done at an engineering works or precision grinders shop.
Bill
