DiscoClax Posted November 12, 2007 Share Posted November 12, 2007 Hi all, My rear window wiper chatters almost always on the way back down. Wipes smoothly on the way up, but skips merrily all the way back to the park position. Tried replacing blades, etc. Doesn't seem to help, or helps only for a few wipes. Arm doesn't seem to have too much play or anything obvious. Do I need to tweak up the spring to provide more tension? Anyone else had this? Any easy fixes? While I'm about it... It also sometimes refuses to work first thing if it's been cold overnight, but then works fine after I drive a few hundred meters or so. Always put that down to "quaint" British character. Doesn't do it always. Weird? Related? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 12, 2007 Share Posted November 12, 2007 I've always found changing the blade sorts it out but you've tried that Maybe the spring in the arm is weak as you suggest. Also often worth trying hosing the screen and the blade with traffic film remover and giving it a scrub with a kitchen scourer so it is all really clean. Quote Link to comment Share on other sites More sharing options...
John Greystrong Posted November 12, 2007 Share Posted November 12, 2007 Hi all,My rear window wiper chatters almost always on the way back down. Wipes smoothly on the way up, but skips merrily all the way back to the park position. Tried replacing blades, etc. Doesn't seem to help, or helps only for a few wipes. Arm doesn't seem to have too much play or anything obvious. Do I need to tweak up the spring to provide more tension? Anyone else had this? Any easy fixes? While I'm about it... It also sometimes refuses to work first thing if it's been cold overnight, but then works fine after I drive a few hundred meters or so. Always put that down to "quaint" British character. Doesn't do it always. Weird? Related? Try bending the arm so the blade sits at 90 degrees to the window. John Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted November 12, 2007 Share Posted November 12, 2007 Try bending the arm so the blade sits at 90 degrees to the window. That worked for me. The arm tends to get a twist in over time & imho just needs resetting to 90o. Quote Link to comment Share on other sites More sharing options...
DiscoClax Posted November 17, 2007 Author Share Posted November 17, 2007 That fixed it. Was well twisted. Cheers guys. Quote Link to comment Share on other sites More sharing options...
