rung and sorted Posted November 29, 2007 Share Posted November 29, 2007 Hello to you all. I'm having a few problems with my 300tdi disco, the motor starts on the button without fail but it wont pick up any rev's, I've changed the fuel filter housing and eliminated the fuel pipes but not sure what to check next..... can somebody please point me in the right direction before i put it into the garage for repair!!1 Many thanks with any help. Paul (My everyday motor) disco 300tdi (my toy) 90 200 tdi (wifes Car) skoda octavia vrs..... ( She is a woman whom like to drive everywhere Fast!!!! ) Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 30, 2007 Share Posted November 30, 2007 Is it a normal 300Tdi or one of the electronically managed EDC versions? Quote Link to comment Share on other sites More sharing options...
lynall Posted November 30, 2007 Share Posted November 30, 2007 Was the old fuel filter full to the brim with diesel if not i would suspect the lift pump first, as they are so cheap i would chenge it anyway. Lynall Quote Link to comment Share on other sites More sharing options...
old110 Posted December 6, 2007 Share Posted December 6, 2007 Hi folks, Have been looking at the forum for a while trying to get my first discovery sorted, but this is my first post! Its a 300tdi which wouldnt rev over 2500 when i bought it. It still doesnt rev too freely until well warmed up but I found a big change after the following, replaced fuel lift pump replaced fuel filter replaced air filter cleaned out intercooler (it was full of ali oxide) checked all hoses/connections. replaced sender pump and replaced fuel lines and sedimentor I plan to adjust the off boost fuelling slightly and move the wastegate actuating hose from the turbo to a fitting screwed into the threaded hole on the the rear of the inlet manifold. I'm going to give my throttle linkages and cable a good going over too. (for some reason my 200tdi 127 seems to rev much more freely.) Wes Quote Link to comment Share on other sites More sharing options...
