smo Posted December 22, 2007 Share Posted December 22, 2007 I'm fitting a new ignition barrel to my TD5 D-Lander, its the same as the one thats come out, however looking at the diagram nothing matches! (The original was removed months ago so cant copy the wiring) HELP! Where do the wires go? (Pin 4 is marked, but there is no pin!) Quote Link to comment Share on other sites More sharing options...
smo Posted December 22, 2007 Author Share Posted December 22, 2007 No one got a TD5 they can look on??? PLEASE! Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted December 22, 2007 Share Posted December 22, 2007 Not got a vehicle to look at here, so it looks as though you have to get cosy with a multimeter. How confident with electrickery are you? Quote Link to comment Share on other sites More sharing options...
smo Posted December 22, 2007 Author Share Posted December 22, 2007 Not confident enough to plug it in and crack on - if i know which one the input was i could figure out the rest with a multi-meter, however its not even clear which pin that should be! Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted December 22, 2007 Share Posted December 22, 2007 Best to try it on the bench with the MM 1 seems a good place to start for the +ve feed. With the switch off, you shouldn't have a connection to any of the other circuits. Then turn key to position 1 or AUX. You should now have a circuit between 1 and 2, and nothing else Position 2 or IGN should give you a circuit between 1 and 2 + 1 and 3 The start position should give you a connection between 1 and 5. You may lose the circuit between 1 and 2. Hope this is of some assistance. Do the cable colours match up with the diagram you have posted? Quote Link to comment Share on other sites More sharing options...
smo Posted December 22, 2007 Author Share Posted December 22, 2007 Yup, cable colours match, just no indication of pins. Ive even dug out the old switch to check the terminals, and sadly there is no sign of wear on the terminals which would at least eliminate one of them! Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted December 22, 2007 Share Posted December 22, 2007 You need to watch more CSI then! CAn you confirm that the new switch has four terminals and the old one had five? You have four wires to connect - yes? Quote Link to comment Share on other sites More sharing options...
smo Posted December 22, 2007 Author Share Posted December 22, 2007 Switches are identical, same number of terminals, same layout, same part number. There are only 4 wires on the car - which all match the diagram. Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted December 22, 2007 Share Posted December 22, 2007 Can't really offer more help than what I have already said above. Unfortunately ( or not ) I am working offshore Brazil, so am not near any sort of vehicle to have a look. Have tried google with no success. Sorry m8y Quote Link to comment Share on other sites More sharing options...
smo Posted December 22, 2007 Author Share Posted December 22, 2007 No worries, cheers for your advice Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted December 22, 2007 Share Posted December 22, 2007 Found this link http://forum.landrovernet.com/showthread.php?t=55062 Might help you in the right direction, but just confused me! Quote Link to comment Share on other sites More sharing options...
smo Posted December 22, 2007 Author Share Posted December 22, 2007 That might just do it - cheers m8 Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted December 22, 2007 Share Posted December 22, 2007 No problem. Got to look busy when I am supposed to be working. :-) Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
smo Posted December 23, 2007 Author Share Posted December 23, 2007 Well the wiring is definalty wrong for a TD5, gave me a fright when i turned the key one position and the engine turns over!!!! So, anyone with the correct wiring sequence please help!! Quote Link to comment Share on other sites More sharing options...
LR90 Posted December 23, 2007 Share Posted December 23, 2007 As Roverdrive ^^^^ get the multimeter out and determine which pins are connected for which key position. Then wires/colours can be matched to the pins. Quote Link to comment Share on other sites More sharing options...
Porny Posted December 24, 2007 Share Posted December 24, 2007 As Roverdrive ^^^^ get the multimeter out and determine which pins are connected for which key position. Then wires/colours can be matched to the pins. Smo.... as mentioned, get the multimeter out However, as long as your loom is in good condtion, with all the spade connectors/covers in place (all on your photo): I'm 99% sure that (I'm not responsible for anything that goes wrong!!!)..... based on a photo I've got lying around: green spade colour to pin 5 red spade cover to pin 1 white/clear space cover to pin 3 black spade cover to 2 I would work out the wire colours etc etc for you, but I haven't got time.... suposed to be Christmas shopping lol!! Ian Quote Link to comment Share on other sites More sharing options...
