bennet Posted December 27, 2007 Share Posted December 27, 2007 Hello all Does anybody know the wheel details for the Freelander offset pcd etc Also whats the widest anybody has fitted? I dont want to go taller ie 17in 0r 18 in i want to go wider!! I think they look awfull with the skinny wheels and i want to fit some chunky type to fill the arches out Cheers Quote Link to comment Share on other sites More sharing options...
Projectblue Posted December 27, 2007 Share Posted December 27, 2007 Hello allDoes anybody know the wheel details for the Freelander offset pcd etc Also whats the widest anybody has fitted? I dont want to go taller ie 17in 0r 18 in i want to go wider!! I think they look awfull with the skinny wheels and i want to fit some chunky type to fill the arches out Cheers Have you considered not fitting wider wheels but spacers? This should bring the tyres out without causing you uneccesary expense? Quote Link to comment Share on other sites More sharing options...
G30RGE Posted December 28, 2007 Share Posted December 28, 2007 Freelander wheels are 114.3 x 5 Biggest diameter you can go to without major modification to wheelarches or fitting lift is around 28.5" Widest I have seen fitted standard is 225 but I am sure with spacers or offset you could get wider on. Beware on wheel purchase Some earlier FL wheels do not fit later models due to offset Quote Link to comment Share on other sites More sharing options...
jules Posted December 28, 2007 Share Posted December 28, 2007 Freelander wheels are 114.3 x 5Biggest diameter you can go to without major modification to wheelarches or fitting lift is around 28.5" Widest I have seen fitted standard is 225 but I am sure with spacers or offset you could get wider on. Beware on wheel purchase Some earlier FL wheels do not fit later models due to offset Nothing to do with the off set there the same new to old in 16" The early wheels don't fit only because the spokes are too big to allow for the larger calipers on the latter models. If you run spacers it doesnt matter what rims you use but would recommend 30mm over 25mm as the studs hit the alloy and you need to drill the inside of the rim. there is more trouble if you go too wide as the spring seat will hit the tyre... My racers run 225/75/16 which do rub the plastic inner wings the gearing is a bit high. The Rally M-sport ones run OZ rims 15" which look very sexy Quote Link to comment Share on other sites More sharing options...
G30RGE Posted December 28, 2007 Share Posted December 28, 2007 Nothing to do with the off set there the same new to old in 16"The early wheels don't fit only because the spokes are too big to allow for the larger calipers on the latter models. If you run spacers it doesnt matter what rims you use but would recommend 30mm over 25mm as the studs hit the alloy and you need to drill the inside of the rim. there is more trouble if you go too wide as the spring seat will hit the tyre... My racers run 225/75/16 which do rub the plastic inner wings the gearing is a bit high. The Rally M-sport ones run OZ rims 15" which look very sexy Stand corrected on offset was what I was told when looking for replacement wheels Which spacers did (or do) you run or recommend Jules? Quote Link to comment Share on other sites More sharing options...
jules Posted December 29, 2007 Share Posted December 29, 2007 Stand corrected on offset was what I was told when looking for replacement wheelsWhich spacers did (or do) you run or recommend Jules? Bearmach do both 25mm and 30mm spacing the wheels off can (not always) make the tyre very close to the wheel arch / foot wells when turning. it a pain but not structurally damaging Quote Link to comment Share on other sites More sharing options...
G30RGE Posted December 29, 2007 Share Posted December 29, 2007 Cheers Julian Now that your Freelander has gone - don't suppose you have any left lying around your garage you want top get rid of Quote Link to comment Share on other sites More sharing options...
