mjjf Posted December 29, 2007 Share Posted December 29, 2007 Hi all, my 2000 td5 disco is starting to misbehave. About 3 weeks ago it started to run really rough, I put this down to bad fuel as I had just fuelled up at a small remote town.In the last week it has started to return intermitantly to a feeling of water in the fuel or a dropped cylinder, pull over stop the car and it may go away. I went and got it plugged into rovacom lite and the chap said that it is probably oil in the computer, that got there from getting into the loom as it passes through the rocker cover and migrating through the copper cores of the wires and into the computer where it causes havoc. He said that it usually takes about 5 years for this to happen and I should replace the part of the loom that passes through the rocker cover, clean the compter with electrical contact cleaner and keep up the contact cleaner on all the terminals for about 3 months. I tried asearch but could not find anything evidently this is quiet a common problem and I thought someone here might have experience of it. Cheers Michael Quote Link to comment Share on other sites More sharing options...
white90 Posted December 29, 2007 Share Posted December 29, 2007 very common issue search for member porny on here he has posted about it I'm sure. Here is one:http://forums.lr4x4.com/index.php?showtopi...l=injector+loom And here http://www.google.co.uk/search?hl=en&q...+loom&meta= Quote Link to comment Share on other sites More sharing options...
smo Posted December 29, 2007 Share Posted December 29, 2007 It is common, but only on the early ones, later TD5's dont suffer the same problem. Clean the contacts, and replace the engine harness and youll be ok Quote Link to comment Share on other sites More sharing options...
Porny Posted December 29, 2007 Share Posted December 29, 2007 As mentioned.... is a common problem. Usually you can just get away with changing the injector harnesss - which is cheap and easy. A new injector harness is £40 (or thereabouts) and to change it all you need to do is remove the rocker cover.... unplug the old harness, and plug the new one in - making sure that the harness correctly latches on each injector (another cause of problems) Then keep cleaning both parts of the red plug at the ECU (i.e. male and female parts)... with a thin screwdriver (or just your nail) you can unclip the white cover part of the red plug, which will give you better access to the terminals... after a bit (and with the new injector harness) the red plug should stay oil free. Ian Quote Link to comment Share on other sites More sharing options...
mjjf Posted December 30, 2007 Author Share Posted December 30, 2007 Thanks for the replies, doesn't seem to be a huge issue (though it should not happen) I will chase a new loom and a few cans of electrical contact cleaner. In days gone by manufacturers kept ironing out the bugs untill the got it right a few examples are LR 2.25, rover v8, ford 250, chrysler/hemi 245, small block chev. Legislation in the EC seems to have stiffled development of existing engines to the point where manufacturers cannot keep up with the chages or did LR chage to new engines for more marketability for new sales. didn't international pickup the build rights to the 300tdi and produce the 2.8 with all the apparant bugs fixed? thanks for the help , catch you soon, Michael Quote Link to comment Share on other sites More sharing options...
