TheBeastie Posted December 30, 2007 Share Posted December 30, 2007 My galvy chassis is now nearly a year old so from what I can gather it should have weathered sufficiently to paint. People suggest not worth painting the chassis itself but I would quite like to do the rear cross member since I think it would look better in black. Given the age would I be right in thinking it would be OK to power wash it well, then red oxide and black paint or should I use a different approach? Whilst at it, I was also looking at tow bar - is this fixed properly? To bolts seem to go horizontally into X member and two go up in from underneath. As far as I can see there is no spreader plate since it appears to be into a box section of the chassis. If normal and OK for towing/recovery that is fine but it has got me wondering. Sorry I know the pic is not great but if anyone wants close ups to help seewhat is happening I will re-do. Thanks Malcy Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted December 30, 2007 Share Posted December 30, 2007 i have no knowledge on the galv chassis but the tow pack i can help with, i believe it has some parts missing but these are easily made or obtained the bar i have circled is what i believe you have missing. Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted December 30, 2007 Share Posted December 30, 2007 The bats are there, well I can just see them. As for painting the chassis, you need to use a eitch primer then a good metal paint. Paul Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted December 30, 2007 Share Posted December 30, 2007 LOL, i looked at the picture again... and yeah you have the bars.... wtf was i on about, i didnt look properly.. sorry! your tow pack look all correct, just make sure everything is nice and tight! Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted December 30, 2007 Author Share Posted December 30, 2007 Thanks guys To be fair, mortus, that was possible the worst photo I have ever posted but it was intended to show the rear X member rather than the tow stuff. There are certainly bars going from the bottom of the vertical bit to the points on the chassis where you would have Jate rings. I will try to post clearer pictures tomorrow since I am more concerned about the point of attachment to the rear X member and what appears to be the lack of spreader plate. Hopefully tomorrow will be a bit drier so I can get underneath to try and show what I am referring to. Thanks Malcy Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted December 31, 2007 Share Posted December 31, 2007 you dont generally have a spreader plate with a normal tow pack. correct me if im wrong. Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted December 31, 2007 Author Share Posted December 31, 2007 I think I have been reading too much about detatching parts! I put the new pictures into a thread headed Towball attachment Thanks and Happy New Year Quote Link to comment Share on other sites More sharing options...
simonb Posted December 31, 2007 Share Posted December 31, 2007 Thanks guysTo be fair, mortus, that was possible the worst photo I have ever posted but it was intended to show the rear X member rather than the tow stuff. There are certainly bars going from the bottom of the vertical bit to the points on the chassis where you would have Jate rings. I will try to post clearer pictures tomorrow since I am more concerned about the point of attachment to the rear X member and what appears to be the lack of spreader plate. Hopefully tomorrow will be a bit drier so I can get underneath to try and show what I am referring to. Thanks Malcy IIRC there are tubes in the rear crossmember to prevent the front and back faces compressing/buckling under load. Quote Link to comment Share on other sites More sharing options...
