GGS Posted December 30, 2007 Share Posted December 30, 2007 The FBH on my 03 Freelander HSE makes a constant humming noise when the engine is running regardless of coolant or external air temperature. Is this normal? Quote Link to comment Share on other sites More sharing options...
jules Posted January 3, 2008 Share Posted January 3, 2008 The FBH on my 03 Freelander HSE makes a constant humming noise when the engine is running regardless of coolant or external air temperature. Is this normal? On the older models it should stop after the engine has bean at normal running temperature for a good few minuets. this could be as long as 20mins from start up depending on ambient temperature. Quote Link to comment Share on other sites More sharing options...
denviks Posted January 3, 2008 Share Posted January 3, 2008 as above mate.........ours does it.... a few mins and its off....up to about 20 mins. can be quite a shock when it starts up :lol: i think it starts kicking in at about 5c Quote Link to comment Share on other sites More sharing options...
GGS Posted January 3, 2008 Author Share Posted January 3, 2008 Thanks! Any idea how to disconnect the FDH completely without removing the front bumper to gain access to the multi-plug? I'm told Fuse 5 Link 1 (under bonnet fuse box) powers the unit but on my Freelander this is designated engine management? Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted January 21, 2008 Share Posted January 21, 2008 The FBH on my 03 Freelander HSE makes a constant humming noise when the engine is running regardless of coolant or external air temperature. Is this normal? Is there hot gas coming out of the FBH exhaust pipe under the front wing? Mine stps after a little while but I can still hear a fan going in that corner even after switching everything off and locking up, it can last for some time. Dennis Quote Link to comment Share on other sites More sharing options...
