TomG Posted December 31, 2007 Share Posted December 31, 2007 Had an idea / suggestion.. how about a 'weights' thread to build up a list of weights of various components / addons / modifications. e.g. if you know the weight of any of the stuff below or can pop it on some scales and post up the weight with a description of what it is. Mods: Perhaps once there's a good number of replies could it be moved into the tech archive? not sure if this will be successful or not but seemed like an idea for folk building / modding I'll drag the scales out to the garage tomorrow and post a couple up. e.g. Chassis 90, 110 Standard or HD / Galv Axles Rover Front, Rover Rear, Salisbury Rear, C303s, 404s Wheel & Tyre Combos e.g 35" Simex on Mach 5's, bigger sizes Gearboxes LT77, LT85, R380, ZF4 Transfer Boxes LT230, Borg Warner Engines 200TDI, 300TDI, TD5, Rover V8 (with or without ancillaries) Bulkhead Bare or with everything attached Bodywork Rear Tub, Van top, bonnet, tailgate Recovery Winches, bumper, rollcage, batteries Quote Link to comment Share on other sites More sharing options...
white90 Posted December 31, 2007 Share Posted December 31, 2007 Good thread idea. A Simex on a Rim (new) = 40kg A BFG MT 255/85/16 (New) on a rim = 35kg High lift jack =12kg rubber floor mats from front= 6kgs high lift base pad =2kg waffles =20kg and some more discussion here Quote Link to comment Share on other sites More sharing options...
TomG Posted December 31, 2007 Author Share Posted December 31, 2007 35x12.5x15 Mud Terrain on 15x10 8 spoke rim = 43KG Rover Front Axle Casing (bare, no innards, no swivels) = 24KG LT230 dry, no linkages or handbrake = 47KG Auto Flywheel & Flexplate for V8 = 8KG Torque Convertor (dry) for 4.6 = 23.5KG Quote Link to comment Share on other sites More sharing options...
mjjf Posted January 2, 2008 Share Posted January 2, 2008 I just wrecked a four door and took the following to the scrap metal yard 4dr body shell, no panels and 100" chassis = 530kg Quote Link to comment Share on other sites More sharing options...
nicks90 Posted January 2, 2008 Share Posted January 2, 2008 I just wrecked a four door and took the following to the scrap metal yard4dr body shell, no panels and 100" chassis = 530kg lightest rangie in existence! chassis must be best part of 750kg on its own....... Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted January 2, 2008 Share Posted January 2, 2008 lightest rangie in existence!chassis must be best part of 750kg on its own....... No way the RRC chassis is 750kg as I can lift it! A bare chassis is more like 250kg. What I have been looking for is a heavy duty fish scales up to 300kg!! Quote Link to comment Share on other sites More sharing options...
