Martin90 Posted January 5, 2008 Share Posted January 5, 2008 Hi there, I'm just completing the wiring on my project 90 and I can't get the reverse lighht working. There seems to be no power getting to trhe light. I have checked the resistance across the switch and it is infinite with the vehicle both in and out of reverse. I'm assuming the resistance should be low when in reverse and that my switch is knackered. Can anyone confirm this please before I buy a new switch or make any other suggestions. Cheers, MArtin Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 5, 2008 Share Posted January 5, 2008 Correct. You probably just need to adjust the switch, if it's new. you should be able to screw it in a few turns to get it to close properly, not too far as it'll stop you selective reverse properly. The ultimate test would be to remove it and push it in yourself. Luke Quote Link to comment Share on other sites More sharing options...
western Posted January 5, 2008 Share Posted January 5, 2008 as Luke suggest, take the switch out so you can check it's plunger operation by hand & visually, when you refit it or a replacement, put the vehicle in reverse, screw in switch until it lights the reverse light(s) then take the gearbox out of reverse & screw the switch in another 1/2 half a turn [180 degrees] run down the locknut & tighten, then recheck the operation of the reverse lights, all should be working & happy Quote Link to comment Share on other sites More sharing options...
Martin90 Posted January 6, 2008 Author Share Posted January 6, 2008 Thanks Guys, I didn't know you could adjust it, makes sense though! I'll have a fiddle with it. Cheers. Martin Quote Link to comment Share on other sites More sharing options...
