Welsh Mechanic Posted February 3, 2008 Share Posted February 3, 2008 Hi, Can anyone help with the above please. I'm trying to remove the injector pump on a spare engine I've bought and have removed the three retaining nuts but still having difficulty. I've taken the front cover off to try to remove the timing pinion but it seems reluctant to come off. There appears to be no retaining pin or bolt but there seems to be a keyway and am reluctant to use a hammer to give it a thump. Can anybody tell me if there is anything I have missed or has anybody had a similar problem. Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted February 3, 2008 Share Posted February 3, 2008 Have you got a manual for this? If not, I have one I can email to you. The drive gear is on a taper and needs a special tool (supposedly) to wind it off. That's once you've lined the pump up properly of course. Quote Link to comment Share on other sites More sharing options...
Welsh Mechanic Posted February 4, 2008 Author Share Posted February 4, 2008 Have you got a manual for this?If not, I have one I can email to you. The drive gear is on a taper and needs a special tool (supposedly) to wind it off. That's once you've lined the pump up properly of course. Thanks for replying to my problem - I was afraid I might need a 'special tool'. If you could email the manual that would be really helpful. Thanks again. Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted February 5, 2008 Share Posted February 5, 2008 You'll need to send me your email address then. PM if you like. Quote Link to comment Share on other sites More sharing options...
sheltie50 Posted February 12, 2008 Share Posted February 12, 2008 I took one apart a few years ago lost the timing marks and coukld not remove the crank damper so could not set it up again, exit left vm ! Quote Link to comment Share on other sites More sharing options...
