COLVERT Posted February 7, 2008 Share Posted February 7, 2008 Hi guys, i have a 3.9 litre and have lack of power when reved at 2000rpm on loads. It seems like it misfires. I changed ecu already but was the same. Changed d ignition module aswell and no change. I dont know y it is done only on 2000rpm only. Any one can help.????? Colvert Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 7, 2008 Share Posted February 7, 2008 Check the technical archive for EFi fault finding / diagnostics guides. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted February 7, 2008 Share Posted February 7, 2008 Do you have a distributor ?? Check vacuum advance.. If stuck / not working may have a negative effect under load. If youhave a system that's a tad fragile, it may be the last straw giving you 7 - 10 degrees advance instead of 20+ !!! Also have a look at fuel filter if fitted and maybe check out fuel pump.. Lack of pressure at the injectors when under the highest load will feel like misfire too... Worth a check.. Neil Quote Link to comment Share on other sites More sharing options...
