The Homba Posted February 15, 2008 Share Posted February 15, 2008 Hi guys just spent the day cutting off the front outrigger on my 110 and there is a big hole behind it . was just wanting to know if this is worth reparing with a plate or am i better off getting a new chassis as i have the other outrigger to do and also the rear cross member have been around the rest of chassis with hammer and all seams fine . your thoughts would be most welcome . Cheers Iain Quote Link to comment Share on other sites More sharing options...
LRDISCOVERY Posted February 15, 2008 Share Posted February 15, 2008 hi weld it all round and make sure you go as far as needed so your on solid metal that will last a long time done right and a hell of a lot less work/cost than a new chassis. jim. Quote Link to comment Share on other sites More sharing options...
muddy Posted February 15, 2008 Share Posted February 15, 2008 That is a nice hole! i would cut the affected area out, get a peice of 3mm plate 2" taller than the chassis and about 6" longer than the hole, then drill a series of holes verticly about 1" in from either end, you can then offer it up and make it in to a small 'c' section and get a decent weld on the top side and bottom of the chassis, aswell as some puddlewelds. Thats just what i would do and i am not a trained person or anything, just my 2p. Will. Quote Link to comment Share on other sites More sharing options...
The Homba Posted February 15, 2008 Author Share Posted February 15, 2008 Thanks for the replies Jim / Will will just be plating it then . just hope the other side is not as bad . Cheers Iain Quote Link to comment Share on other sites More sharing options...
muddy Posted February 15, 2008 Share Posted February 15, 2008 just keep on plating and you will have a new chassis in a few years Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 15, 2008 Share Posted February 15, 2008 Don't just cut all the rot out in one go - you might weaken the chassis enough that the weight of the vehicle deforms it. I would cut the side out first as it's doing nothing with regards to chassis strength (the top does at least have a 'spine' still), then the top. Once it's repaired, then fit the new outrigger. If you put the repair plates on the top of the chassis - rather than 'in the hole' - make sure that the fact that the outrigger is a bit further out than before will not matter - especially with bulkhead outriggers, as the fit is tight anyway usually. I'm surprised that the bottom hasn't gone through as well - it's usual to find a hole behind where an outrigger was. I would suspect that the bottom may be very thin at least. Les. Quote Link to comment Share on other sites More sharing options...
The Homba Posted February 15, 2008 Author Share Posted February 15, 2008 at Muddy .. Les thanks for the advice poked a chisel in there and it all seams solid was thinking of doing it that way but making it flush with the chassis . i have my brother in law coming over to do the welding for me as he a welder to trade all i got to do is prep it for him ( my welding ok but with it being a stressed area thought i would get him to do it ). On another note how can you tell what swivel seal to get as i not sure what axle it is . it could be off a RRC as it got two steering dampers . Cheers Iain Quote Link to comment Share on other sites More sharing options...
