200TDi won't start!
As above check wire coming out of the back of the ignition switch for 12v when key is turned to the III position. Wire should be white with a red stripe. If you don't av 12v to chasis earth then try to engine earth. If nothing then it'll likely be the ignition switch.
If you got 12v then check that you are getting the same 12v at the starter solenoid. If you are then the starter solenoid / motor is dead. ;)
