wozzer uk Posted February 21, 2008 Share Posted February 21, 2008 having problems in fitting the carrier here goes :- the problem being is fitting the four 10mm headed bolts 2 of them want to go through the reinforced ribs that i have just riveted on also its bolts on half on the square plate and half off any answers or pics would be appreciated the bolts by crossmemeber and rear light no prob went on ok bit of a shame as it also bolts on were my rear nas step does Quote Link to comment Share on other sites More sharing options...
western Posted February 21, 2008 Share Posted February 21, 2008 A photo of the problem areas would help. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted February 21, 2008 Share Posted February 21, 2008 Here's the paddocks one i used to have on my 90.... hope these help. the square metal plate on the door fitted directly over the holes that used to hold the wheel carrier in place. when fitted mine, i removed the rubber stopper thing, then offered up the "arm" and marked & drilled the holes, then refitted the rubber. that way, when you close the door, the rubber thing gets nicely compressed and results in a nice rattle free carrier. if you just try to compress it by hand, then mark the holes, you'll never get it "tight" enough. Quote Link to comment Share on other sites More sharing options...
wozzer uk Posted February 23, 2008 Author Share Posted February 23, 2008 cheers that info great pics a real help Quote Link to comment Share on other sites More sharing options...
scrumps Posted February 23, 2008 Share Posted February 23, 2008 cheers that info great pics a real help Hi, On my "old" 90CSW I fitted a Bearmach swingaway, which looks remarkebly like the Paddocks one. I scrapped the small metal plate supplied with it and made a larger one out of stainless. This covers the full extent of the LR wheel carrier re-inforcement on the rear door and makes for a better job. Photos enclosed. Hope this helps Scrumps Quote Link to comment Share on other sites More sharing options...
